Is This Normal?
duggu
Is This Normal?
I played subway surfer for 5 mins and later was browsing on chrome for some time and i got my battery temperature as 42.
the battery indicator showed it in yellow colour which means warning?
Normally when phone is idle the temperature is between 27-34 degress.
10 REPLIES 10
Samuel1
Hero
Seems normal. The phone gets warm when using power hungry processes in the phone (like games, wifi, mobile data, calling, etc) but it has built in functions to prevent overheating. If the phone gets to warm it will shut down processes and if the temperature gets to high, you will be notified and then the phone will shut down.
Ronaldfromholla
And the batteryindicator is red because it is close to drained 14%, has nothing to do with temperature
duggu
I am not talking about battery indicator,my bad..:smileysilly:
I meant to say out the indicator which is showing temperature as 42 in yellow colour.
duggu
But as I use 3g on mobile,the battery also drains at a very faster rate than usual.like 10% for 30 minutes.
And also the stamina mode is not working.Whether I activate or deactivate it shows same time. I have done factory reset 2 times.
think its a software bug.Please fix it in next update.
TheEntelexia
To get the stamina mode function working again go to Settings>Apps>All> Eco Mode Controller>Force Stop>Clear Data>Restart phone> Ta Da!
duggu
I have done the same thing more than 4 times now... But again after 1- 2 days it gets stuck....thats why I said its a software bug
TheEntelexia
I only have done it once and It worked for me and I haven't had the issue come back. Just trying to help.
Uliwooly
which build number do you have?
also you do NOT need battery apps, taskillers, antivirus, ram apps, booster apps.
duggu
Yeah i am on 10.1.A.1.434
