is this normal???
Lord_viridis
is this normal???
Hi, I just got my sgp321 today, at first I thought all was good but when watching a movie tonight I began to get distracted by the lower right and bottom of the screen.
The screen is not uniform at all and there are quite a few bright patches along the edges. It's not like the standard glow from changing angles, they are very distinct in where they are.
I'll post some pics but please bear in mind I've taken them on z2 so exmor has kicked in a bit.
The background pic on tab is just solid black image viewed in album.
1
2
3
SonOfaBeach
I have something similar on my SGP311 but nowhere near as bad as yours seems. Mine are at the bottom of the screen too. I guess it's the risk they took in the design/manufacturing to get their screen as thin as possible.
I find mine tolerable, like you say it's only when the screen is black. If it bugs you then I'd say to take it back to the store and exchange it, it would bug me if mine was that bad. I don't know how normal it is but I'd say you got unlucky.
I assume that the coluration in the photos was just when taking the photo.
Lord_viridis
Yeah, the exmor really seemed to amp the problem up and the screen angle glow is a little too evident.
I've decided to live with it as it's only when it's dark it's a problem and even then only if dark images are on screen.
Lord_viridis
This is why it's kind of distracting while watching movies.
Would this come under warranty?
