Hi, my old 770i will not read my memory card , sometimes it says it needs formatting but it then says formatting unsuccessful, when you try it.the card works fine in my sons identical phone and formats in his phone as it should. a brand new card does exactly the same thing. initially it says it needs fomatting but it cant do it ,from then on it says memory stick not inserted, i have updated the software on the pc but this made no difference, has anyone got any ideas ?
regards colin.
You can try phone repair via PC suite and see whether that resolves the problem.Failing that, try a master reset.
