hi, i havnt used my k800i for quite some time and now wanted to test if everying works since im gona give it away.
ive installed the pc suit wich updated to pc companion 2.0, after i plugged in the phone the program showed that there was a update avail so i followed the instructions fully,
the last step was to unplugg the phone, remove and insert the battery and start it, all whent fine.
but every time i pluggin the phone and start the pc companion it keeps showing that there is a update avail..
ive used the phones own update to search for a new update but that tells me that i have the current one so why does the pc companion keep telling me that an update is avail?
and another thing, with pc comanion i cant access the memory card when i want to use the explorer function, in my opionion the Pc Suit was much more functional than the crappy pc companion..
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/k800i?cc=gb&lc=en Your phone's own update service is most likely correct when saying that you have the latest update.You can download PC suite for your phone from this link or use My Phone Explorer, which is also free to download and use.
Hello.
Where can I find the Sony Ericsson K800i update policy for Europe, it would be nice if I could get the language Finland.
Thank you..
