Hi.
i have xperia d6503 but i can not connect or see on LTE here..there are two provider movistar and claro..why?..(my phone is from spain original)..
Thanks a lot
Hi @elidexter,
Welcome to the community.
Can you please go to Settings > More > Mobile Networks > Preferred network type. Make sure LTE or 4G is selected here.
Hi CameronT.
I tried it...but is not working..here some image
I even tried it...connect manual not automatic..i can see lte network for my carrier and the other..but if i try to connect to Claro LTE..i give this error..
i have chip LTE..can see LTE network...but i can not connect..i try with the other carrier and same case..i can not connect lo LTE.
What can i do?
Have you contacted your network and checked that 4G is enabled on your account?
they said me yes..configured access point, simcard LTE, access to network LTE..as i say you last message...it's not working for claro or movistar..same problem.
It's possible that the bands for LTE in Nicaragua differ from the ones used in Spain. The only other thing I can suggest is to try another SIM card in the phone. Can you please do this and let me know?
i even tried the only two telephony operators that exist here...not working.
here some information:
Claro Nicaragua: LTE band 1700 o 2100
Movistar Nicaragua:LTE 900mhz. or band 2
i understand than this model (d6503) has this bands for the two operatory..or not??
Try it in safe mode and see if the same thing is happening. If it is, run a software repair using Xperia Companion.
Hi Cameron.
Sorry...i tried safe mode and repair and is not working
No idea..?..:smileyrolleyes:
