I have 2 Sony Ericsson MBS-200 bluetooth speakers. Hoped I would be able to pair both to work at same time with my iphone 4 but they show as 2 separate bluetooth options - so can only send to 1 or the other not both at same time . I know I can join the with a wire but that was exactly what I didn't want to have to do. Anyone know if it's possible ?? Thanks
From what I've read about the iphone, it can't connect to more than one BT device at the same time, and the iphone's issues with BT in general are well known in the mobile phone industry. On the W995 there is a Power save option which when switched off allows for multiple BT connections, although I don't know if there's such an option on the iphone.
Thank you for that. Have resold the 2nd speaker to one of a number of friends who fancied one after seeing ine - under £15 at the moment in UK so good value. Disappointed I can't have stereo though !
http://www.amazon.co.uk/Supertooth-Portable-Bluetooth-Stereo-Speaker/dp/B002G1Y7LO/ref=sr_1_4?ie=UTF... Have a look at this if you want a stereo BT speaker.
