micro SD / Charging port flap broken
rmcgrath1705
Hi all,
My flap for the micro SD port and charging area has snapped.
The little part which goes inside the phone has disconnected from the flap.
Please can someone advice how can I get a new flap?
Thanks,
Ryan
6 REPLIES 6
Phy
Legend
Legend
Phy
Legend
Legend
or you can buy them from amazon, they aren't too expensive
kabillion
rmcgrath1705
Thanks I bought the part from Amazon in the end
vezer
Hi guys,
I got a problem with the micro SD flap. The waterproof rubber seal is partly unsticked and I can't close the flap. I've already order a new flap but till then can I remove completly the rubber and to close the flap? I know that in this way the device wouldn't be waterproof anymore, bit it's fine to me for the next couple of weeks.
MrG73
Thanks just bought it from Amazon (as also recommended by EE)  too fingers crossed it'll work.
