There could be a few different reasons for this, however if you have concerns regarding the water resistance of the product you are best to speak directly with your local Xperia Care team regarding having an assessment performed.
What are your thoughts about this forum? Let us know by doing this short survey.
@ShizuruShu wrote:
Hi kaboo. How many hours did you put your unit with rice? And are the flaps open?. I have the same issue regarding moisture in camera and flash. But mine doesnt gone. What will i do? And did the moisture never came back after you put it on rice?
Hi, another good trick is to open up the flaps...take a 4k video, this heats up the phone & hopefuly dispells the moisture....you may have to do this a couple of times...
Hope this helps:smileysmileywink:
Best solution now is to first take the Z2 back to where you purchased it & explain everything that has happened......either that or contact your local Xperia Care Centre, but my first port of call would be where you purchased it
Good luck:smileysmileywink:
