Hi i want to know if this is a common problem, i've had my phone around 12 months with the only problem being it getting very hot. I installed the new update and again had no imediate problems until 2 weeks ago and i was playing on an app while my phone was on charge when it started to get very hot to the point were it was to hot to touch, shortly after it switched itself off.
since then it has not come back on correctly first it was coudln't stay on for long, now i get to the sony image and that is all.
I haven't got sony companion installed on pc and i can't get the phone to register when plugged into the usb.
Any help would be much appreciated.
Thanks in advance.
Jazbag
i will try that thank you ^^
i didn't realize that playing while charging would cause that to happen thank you for the advice it is much appreciated ^^
