MW1 Headset Pro 0.1.E.1.6 Major issues
Nikitas
Please see attached bad reviews on the new update 0.1.E.1.6
Main problem is that media audio is keeping disconnecting.
See following link with bad reviews on teh update. http://www.badappreviews.com/apps/139649/smart-wireless-headset-pro
Sony support team should at least aknowledge the problem/messages. It becams really annoying
aman jassi- This one is bad update too
Although no sound stuttering in this update. But sound completely lost when connected with laptop or samsung s2. So this is worst update. Sony updates s**ks. I have to try 10 to 15 times to connect and to get it fully functional.
Date: 2013-07-09 Device: Samsung Galaxy S2 with version 1.1.30 using Smart Wireless Headset pro
Victor Ling- Unable to use after update
Can't use for music no more after updating xperia z n the new firmware. Only connected to phone...Please fix!!!
Date: 2013-07-04 Device: using Smart Wireless Headset pro
sameer batavia- faulty
not working not working bluetooth gets connected to phone audio only no media if I manually click the phone doesn't accept
Date: 2013-06-18 Device: Version 1.1.30 using Smart Wireless Headset pro
Joey Cheng- Poor update
After update, it is failed to connect mobile's media audio!!! The songs in sd card cannot be auto repeat all!!! The Bluetooth would suddenly disconnected and re-connected itself!!!! Can't downgrade the firmware by downloading the old one!!!!
Date: 2013-06-18 Device: Version 1.1.24 using Smart Wireless Headset pro
Gerald Galvez- Doesn't work on HTC ONE
I installed the app in my HTC ONE and the app doesn't appear in my app drawer.
Date: 2013-06-18 Device: Version 1.1.26 using Smart Wireless Headset pro
Date: 2013-06-17 Device: Version 1.1.24 using Smart Wireless Headset pro
Farooq Mirza- Skipping
Will not update. Stuck on a loop. I was one of the first people to get this headset, spent over £ 100. Have been using a wired headset for the last few months.
Date: 2013-06-10 Device: Version 1.1.30 using Smart Wireless Headset pro
Why it is failed to connect mo bile with media profile after update!!!
Date: 2013-06-05 Device: Version 1.1.24 using Smart Wireless Headset pro
Wei Chean Ooi- Worse Update Ever !!!
Worse updates ever that release by Sony, Spoil Sony Reputation & Spoil User Trust. (Now I rather use direct earphone plug-in) Update halfway stuck, unable to use, restart phone & MW1 also useless. Sony make my MW01 became a Peace of JUNK! Can Refund?
Date: 2013-05-30 Device: Version 1.1.30 using Smart Wireless Headset pro
Madhu PK- Irritating update
Overall this is a poor update. I noticed a problem which is annoying. Keeps repeatedly disconnecting from phone's media audio. I have to reconnect every time I want to listen to phone's media on headset. No problem with music player on the headset. No folder browsing on sd card this time too.
Date: 2013-05-29 Device: Version 1.1.26 using Smart Wireless Headset pro
Dudley Loynd- Another New update is useless
Please please please fix media connection can't use text to speech or satnav
Date: 2013-05-29 Device: Samsung Galaxy S3 with version 1.1.26 using Smart Wireless Headset pro
