My lock button and volume buttons arn't working....
cinta2805
My Lock button and volume buttons arn't working....
My phone is fully fuctional though, i put it on the charger to charge it and the screen flashes up, that being the only possible way to check my messages and use my phone...
Ive tried connecting to my PC and it doesnt work either..
How can i fix this, Please help!!
5 REPLIES 5
Ahmar
try an update/repair in this case:
1. Before you start you have to download the PC Companion software fromhttp://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Note! For some models you will be prompted to do a backup prior to the update and then restore.
3. Install and open PC Companion then select Support Zone.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
if this doesnt work then it is hardware problem.for that go to ur local sony center and use the warranty.
cinta2805
My Phone wouldnt connect to the computer and has now lost all power.
Which is really really sad Slightly_frowning_Face
Is there anyway of getting it back again?
It will not connect to a computer, i had it on charge for 8 hrs and nothing happened.
and the lock button isnt working so i cant turn it on at all?
Samuel1
Hero
Did you follow the instructions presented by PC Companion? You phone should be turned off when you perform the repair.
cinta2805
Yes i have tried. and it isnt connecting.
Samuel1
Hero
Well, in that case I'd recommend that you send in the phone to a service center for repair as it's not much you can do by yourself. Contact your local Xperia Support for more info.
http://www.sonymobile.com/global-en/support/contact-us/
