My phone is not detecting headphone. Can anyone of you advise me what to do?
What kind of headset are you using? Standard OMTP or CTIA? Brand? Model?
Sony Xperia Miro & Tipo/Tipo Dual are using the standard CTIA so the headset also have to be CTIA.
Standard CTIA.
Ok, can you try to connect another headset (ex. one from Sony) and see if that works?
Yeah i tried that one also but of no use. In live manager it shows headphones connected even though i hv not connectd any.
