my xperia miro stop work
ma7moud88
my phone stop work totally >> after i setup a custome rom >> not respound to any thing >> and stop charge or even light  ??
9 REPLIES 9
Uliwooly
reflash the Custom ROM
ma7moud88
the stop totally i cant startup the phone
Uliwooly
Check the XDA forum and see if other users have the same issue.
Uliwooly
what if you flash it
How to manually update, downgrade, root 2012 Xperias
http://talk.sonymobile.com/thread/41609
ma7moud88
i dont think so .. my phone not reapond to flashmode or fastmode also >> i cant statup the phone >> thank u for help.
ma7moud88
do u think may he power cycle was break ??
Uliwooly
Try this
install SUS > restart your PC > press and hold power & volume up until the phone turns off > once the phone is off  > run SUS > press and hold volume down > connect the usb cable if that doesn't work then > release volume down and press and hold power & volume up until the phone vibrates, once it does release this keys and press volume down
Don't forget to give Kudos
ma7moud88
thanks .. the problem is still bcuz my ohone not respond to any thing ..
Uliwooly
Sorry you will have to take it to a Sony repair center
