My Z3's battery dropped from 24% to %0 suddenly, no vibration
Fatihcara
I've several problems with my 8 mouths old z3. Today my battery was suddenly dead. And vibration doesn't work. I always use my original charger and never put it into water or washed it. It overheats without any intense usage. My question is, I'm afraid to send my phone to warranty because of my bad experiences like waiting for an answer about my phone for 1 mouth etc. Also i wonder if warranty will cover it because i don't have enough money to spend these days.
Thank you in advance
13 REPLIES 13
Fatihcara
Edit: here is the screenshot of battery usage section http://imgur.com/WsM1vuI
Phy
Legend
Legend
The problem is that you have WiFi on all the time and there's an app or apps that keep your phone awake. After charging your phone 100% boot on safe mode and check if you experience the same behavior?
Phy
Legend
Legend
How to boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
How to boot on safe mode on Lolipop
1. press and hold the power key
2. once you get the pop up menu
3. press and hold "power off"
4. Boot on safe mode should become available
Fatihcara
Thanks for the reply, i'll try the safe mode trick, but i don't think it's because of wifi, it's always been on and caused no problems
Uliwooly
@Fatihcara
I agree with @Phy, the graph show that the WiFi its on all the time, that will drain quite a bit of your battery
Fatihcara
But the point u don't see here is the sudden drop from about 25% to 0%. U the graph goes down at around 8 o'clock. And also vibration doesnt work whatever i try
Uliwooly
@Fatihcara
Indeed that doesn't look normal, what I would do is to repair the phone with PCC
software repair using PC Companion
it could be a bug or it could be an app acting up
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Fatihcara
Thanks for the reply. Im thinking about soft repair. By the way, vibration problem happened several days before battery issue. So it may be a hardware problem. I wonder if the warranty covers that or not
Uliwooly
@Fatihcara
Only your Local support could answer that question after they have inspected the phone.
