I also noted the following apps on the handset on reciept and they remain on factory reset:
Music Go
TV Go
Cyberon....App in Chinese.
See attached pictures.
The following contacts at Sony were asked to respond in English, but Ive seen nothing helpful :
questions.cn[at]support.sonymobile.com
Ive asked the seller and the local distributors with no luck.
The distributors were SoldSA/Active Cellular SA through [removed] and [removed].
The following persons were contacted.
[removed],
questions.za[at]support.sonymobile.com,
questions.AE[at]support.sonymobile.com
[removed]
[removed]
Please see the apps below and advise:
Hi @mahdev,
Welcome to the community.
If they're still there after a factory reset they may be built into the firmware version you have on this device.
Can you try a software repair and see if they disappear afterwards?
