Nearly full internal memory concern
Raven_Knight_CZ
Hi good day, I have installed many applications in my xperia L already and it started showing the notification about the internal memory being nearly full and I know that I can normally transfer the appdata from the internal storage to the sd card, any way to bresolve this or is there any way to trandfer the appdata to the sd card?
Er_Kannan
Only some applications support moving to SD card. Unfortunately most popular applications do not support this feature.
Install a cache cleaner like Clean Master from Google Play. That will remove a lot of junk data for you. Try to uninstall unwanted applications.
Alexander1
Champion
It's not possible to move apps to SD card in Xperia L.
You a phone memory and an internal storage in your Xperia L. You can move apps between phone memory and internal storage if you go to settings > apps > the tab internal > press on an app > move to internal storage/phone memory.
