I am unable to see the USB tethering option in my Xperia Tipo Dual phone.
I can only see WiFi hotspot option.
Hence unable to use the Internet connection.
My company provided laptop cannot connect via W-Fi due to policy restrictions set.
Please help me how can I get the same.
Also whenever I connect using USB, the "USB Debugging" option is automatically set even if I disable it.
Vinayak
When you connect the USB cable are you then checking the Tethering section? or does it not matter with USB cable connected or not?
What are your thoughts about this forum? Let us know by doing this short survey.
