Ogg player - Naite
Ogg player - Naite
Hi everyone,
I have all my music in mp3 and ogg format. And, I tried to read it in my Sony Ericsson Naite, apparently it is impossible to play ogg.
There is some way to get this phone to play ogg?
TDF
6 REPLIES 6
KrazyD
No, there isn't any way to play ogg files on the Sony Ericsson Naite.
Dr_Chris
Champion
What you could do, is use an audio file format converter such as Switch to convert your.ogg files into .mp3 or other file format compatible with your phone.
I suppose that this answer my question, although I'm not happy with it.
Yes, i know that I can convert formats... but it's not the solution I was looking for.
Thanks anyway
Dr_Chris
Champion
Well I don't know of any Java phones that can play .ogg format files, so what solution were you looking for?
I was willing to know if it is possible to play ogg without converting. If I could install something to make my phone read ogg, why should I convert files?
But, I understand that there is no hope on that, and converting is the only solution.
Thank you
