PC Sync
PC Sync
Hi All,
   Is there a way to sync my Cedar to the PC (Backup) w/o connecting to the Internet? I am using Sony Ericcson PC Companion.... or is there another software that I should use?
4 REPLIES 4
Hi there,
PC Companion is the only applcation we provide to perform this, you can use the Backup or Sync options available in PC Companion. You can also check pages 40 and 53 of the user guide for help
http://www.sonyericsson.com/cws/download/1/835/750/1296738239/J108i-J108a__UG_EN_1241-2576_2.pdf
There is also a third party application MyPhoneExplorer (www.fjsoft.at) although as it not supplied by ourselves we cannot offer support for it
Ok, but is there a way to disable the "PC Companion" from connecting to the Internet everytime I try to do a backup or something?
No unfortunately PC Companion does not have any settings relating to this
