PC USB connection issue
RaidenMGR
Hello.
I have an issue connecting my T to pc, sometimes will connect normally but most of the times pc companion will come up with an error saying, "the was a connection failure, unplug USB restart phone and plug again after 5 minutes" this started recently as i never had anything like this before...i uninstalled pc companion installed again but the same...i tried on my new laptop which didnt had pc companion installed so i downloaded first time for my laptop but still does the same. the phone its in a like new condition and i already removed many apps and deleted some unnecessary folders, so seriously what might be the reason of that connection failure? maybe if i do a repair on the firmware will solve it?
Thank you.
10 REPLIES 10
Uliwooly
Does this happen while you transfer files ?
Uliwooly
@RaidenMGR
It doesn't hurt to repair the phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
RaidenMGR
No i cant transfer anything since i cant see my files, the phone keeps connecting but this goes on like forever and after 2-3 mins pc companion gives me the error " there was a connection failure etc" so i just unplug the phone and plug it again trying to have an established connection. for example will connect 1 time out of 5.
Uliwooly
Could you try a different USB cable?
@RaidenMGR
RaidenMGR
i tried 2 already, 1 was the normal cable with came with the phone the other 1 is a 3rd party usb cable, does the same on both cables..seems i go for a repair and i hope this will be solved
Uliwooly
Sorry to hear that, this is how to contact Sony directly
http://support.sonymobile.com/global-en/contactUs/
RaidenMGR
Thank you for your help, good news is if something is wrong and its not software related i still have warranty!
Uliwooly
Keep us updated Slightly_smiling_Face
RaidenMGR
Seems that phone had a lot of trash inside internal memory..problem solved with a restore to factory default settings + delete everything inside internal memory!!!
