Poor reception quality and RadioFM error
soniak87
Hi, I have not bought a new Sony Xperia XA1 (G3112) smartphone. I'm in Poland. I connected the headset with the model Sony MH410 to my smartphone, I turned on the FM radio for the first time and searched for stations. FM radio is poor quality radio reception and interference. Per 100% is software fault or Firmware. Previous smarton I had this Sony Xperia Z3 (D6603) I had no reception problems FM radio all stations was fine, and XA1 has a serious problem RadioFM software. Same position of the handset antenna in the same place. RadioFM applications have an error. Software repair and safe mode, I tried the same, but without effect. Does anyone have the same problem? Has anyone tested it? Will Sony Mobile update the updates as soon as possible?
0 REPLIES 0
