Power button problem
Drw658
My Xperia T LP30 has a strange issue... The power button will not wake up the phone or sometimes does wake but with 20-30 seconds lag and also does not send the phone back to lock screen when I'm done!
I can wake my phone by using the camera button and it wakes fine if I am called etc...
Also it times it appears like the power button is being pressed when I am nowhere near it... I can be using the phone and suddenly the little power off / airplane mode window will appear constantly as if the power button is being pressed repeatedly.
Any ideas? ... I have done the full SUS reinstalls etc so pretty sure it's not a software glitch
Thanks for any help.
Hampus
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Did you restore any back up after you performed a software repair? Or installed any applications?
You can always try to boot your phone into safe mode to see if you experience the same behaviour:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Drw658
Thanks.
I just tried the safe mode but no luck, I still have the same issue.
I didn't restore any backups but as I setup my google account details again all my regular apps have reinstalled.
Hampus
Champion
Okay, in this case I suggest that you visit nearest service center so a technician can examine your unit. You can contact your local support team for information about nearest service center and/or how to proceed with this in the best possible way:
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
