problem capturing image while using flash
sunny17192
its been around 10 days i bought xperia p
i noticed that when i capture images while using flash and if the object is close to camera (even at 6-7 feet)
half side(left) of the image comes to be totally black
plesae help (no such problem in video recording with flash)
7 REPLIES 7
jackxperiaP
repair the device with SUS or PCC with a factory reset .. Slightly_smiling_Face
sunny17192
i am new to android
what is SUS and what is procedure of repair
using PCC and SUS
profile.country.RO.title
_alexdon_
Are you still on ICS?ICS had this kind of problem.SUS is Sony update service,an app that helps you update or repair your phone's software.
http://www.sonymobile.com/gb/tools/update-service/
alexdon
Nalee
Update your phone firemware to the latest one using SUS
sunny17192
DSC_2275-001.jpgthis is the kind of problem with my device
sunny17192
yes i am on ICS
what should i go with SUS or PCC
and how(procedure)
jackxperiaP
go to the link alexdon provided.. install that software in your pc.. then connect ur device to the pc and open the software .. then follow the instructions there in the screen to update ur mobile..
