problem while playing mkv file, no audio
pbrreddy
Modiel: Sony Xperia U
I am trying to play the mkv files, vedio is very good but no audio.I have tried with many players like MX, Mobo, VLC.
Can someone help me out on this, do I need to install any specific Codec. All other format are playing good.
Thanks,
Bhaskar
14 REPLIES 14
pbrreddy
finally tried with Vplayer and now its fine. thanks all.
Bardia
Please Click Correct Answers to help others.
Sumantaghora
Just go through this link bellow
http://forum.xda-developers.com/showthread.php?t=2156254
scroll down & download it.
  1. Arm v7-Neon [MD5: ad4fa04b306c894015ba21729ef0f05a]
  2. After download it unzip and put into your sd card or your internal memory with create a folder.
  3. You can give any name of the folder.
  4. Then just paste that file which is already downloaded on new create folder.
  5. Then open mx player got to settings then decoder.
  6. Use H/W+ decoder enable it.
  7. Then scroll down from your phone.
  8. Go to Custom Codec.
  9. Select the folder you are already created on your device sd card or internal memory.
  10. You can see the codec just select it. your mx player restart then you play mkv file with audio.
  11. Done.
Sumantaghora
  11. Done.
dear_navratan
Try KM Player, Hope it will work on your mobile also.
