Questions about a new Xperia U; texts, balance on screen, apps.
amia33
Hi all.
I've had my Xperia U for a few weeks now and have noticed a few things that are annoying me, and not working as I'd expect them to. It is my first smartphone though, so perhaps that's just how they work. Anyway, any help with the following issues would be really appreciated!
1) Only in the last three days or so, my texts are constantly opening to a discussion with one particular person, despite the fact that she's not the last person I texted, and I always exit out of discussions before returning to my home screen. Anyone got any idea what's going on there?
2) Whenever I send a text or make a call, afterwards it displays my balance on screen - but if a text is more than one page, it will display the balance more than once. As I often send long texts, this is utterly tedious. I'm sure there must be a simple setting to change this, but for the life of me I can't work it out.
3) There are loads of apps that came pre-installed, which I don't have a clue what they do and I'm not sure if they're necessary to the running of the phone or if I can get rid of them. Does anyone have any advice about anything I really shouldn't get rid of, or what I could easily do without?
Thank you very much in advance for any help you can give! As a novice, I really appreciate it!
Fahim715
You can try disable or uninstall your pre-installed app.. Goto Setting --> Application/Apps --> App name -->Uninstall or Disable
I'm a newbie too.. Slightly_smiling_Face
