Quick charge
ARBN
Quick charge
Hey there.
In a few days ago, I discovered my phone charging slowly.
How can I find, if my phone charging with quick charger on the go, or it just charging normaly?
Before my it was so fast, but as I said in few days ago, it just charging so slowly
Uliwooly
You will have to give us more info, how long does it take from 0 to 100?
which charger are you using?
are you using a Sony USB cable?
ARBN
I never put my phone in charge from 0 to 100
I always plug charger at 20% and remove it at 80% (sometimes +- 10%)
so i dont know how long it takes, but before, for example after 10 - 15 mins phone could charge for 20 or 25% after i pluged charger. but now it just change for 10%
it's better i say, i think quick charge has been disabled (it's looks like i pluging normal charger)
And yes im using sony's cable and charger too (UCH 10 + the cable in box)
Uliwooly
If possible test it while the phone it's off and in safe mode
