I have got an xperia Z3 device and so far everything has been working fine. Since the latest android update however (lollipop), my phone is constantly rebooting itself, when i want to perform a simple restart. I tried the pcc repair tool twice already. it works, but as soon as i want to restart my device, it gets stuck in a reboot loop.
I also tried removing the sim card. It still gets stuck in a reboot loop.
The question I now have is the following. Is this problem gonna fix itself with an update / bugfix or similar, or do i really have to return my phone and get a new one?
Thanks for any information.
thanks for your response.
I used pcc repair tool once more and removed my sd card before.
I tried safe boot --> worked.
I then restartet normally --> worked!
I am not sure though, if my problem is solved now. What will happen if I put my SD card back in ?
Is this a known issue that already has a workaround? Should i format my sd card before putting it back in?
I would really like to use my sd card.
At least i can use my phone again, i appreciate your support! Any futher information are welcome.
Hi to all,
I have a big problem with my Xperia Z3, I updated it lollipop 5.0.2 couple of days ago. It worked fine with no issue until yesterday (Saturday 04.04.2015) when I left it in my car for the gym session as always. When I came back to check missed calls, I couldn’t access the phone at all, only a black screen and I could see a clock and partial notification bar. I switched it off and the on again.
Now its stuck at” Android upgrading, starting apps” all the time and it keeps restarting. I have tried to soft –reset nothing is happening. I have reached at a level to lose everything in the phone especially my contacts by deciding to do a hard/factory reset but still I cant do that using volume up or down. I am totally stuck, I also tried to boot into recovery mode but with no luck.
Please guys any idea how to get rid of this. I cant get into recovery mode coz nothing is happening when I press key combination.
I will appreciate your help. At this point I regret why I updated my phone to lollipop.
Please help help………
Try performing a system repair using PC Companion - This will factory reset your phone and erase all data
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
HI
Thanks for quick response, unfortunity the phone keeps on resparting all the time and it cannot arrow the sony pc companion to detect it. I am totlally stuck becuase i can do nothing not even recovery more nor factory reset becuase i cant access main manu or to unlock it, I have attached a pic of of the roop.
Thanks once again. I am looking forward for futher help
Are you saying your phone isn't recognised in flashmode or are you not performing it correctly - you don't select update
Hi Thommo,
The phone is not recognised, the moment it switches on before pressing unlock screen, it starts "upgrading android apps, starting apps" from there, i can do nothing then after loading and loading then it fails, it reboots again and it keeps doing the same thing. When i connect to pc, it wont show up in sony companion becuase its still locked and i cant access anything on the screen as u can see in the image i upload. it pops up in the pc then restarts before its being recognised. .
I cant tell really what the heck is going on with lollipop. I haven't used flashmode yet i download the sony flashtool but then registered a new account but for reason, i cant get my account approved coz i dont recieve the comfirmation email. and i have tried two gmail accounts
Please advice if there is any other way i can resolve this becuase at the moment i dont have another option coz my sim isn't compatible with other ordinary phones.
Thanks again,
John
