i have downloaded 2 ringtones from vodafone live and when i got them i could only use them if i pressed on use now but as i couldnt use both they both went into setting >sounds and alerts>ringtone there are there (with an unlocked padlock next to them) but when i select to use all i get is the original ringtone it was on when i got the phone i can listen to them as music but as they are ringtones they are not the full songs and that is pointless iv done the taking apart the phone to update it but that did nothing. i just dont know what to do and i feel like iv wasted my money
i have a sony ericsson spiro by the way
can any 1 help me ??
Why don't you try going to the file manager and trying to set up the file as a ring tone from there?
Please try this out and let me know what error message you get if applicable.
it does not matter as i hav deleted them and got my money back from vodafone live i will look at getting then from here as they should be ok on my phone as its a sony ericsson but the only thing i dont know is how to pay for them (the ring tones) with credit from my phone
I see. If you already deleted the files from your phone, you could download some ringtones from www.sonyericsson.com if you access from your phone. Keep in mind that you can't download it to your computer and then transfer it to the phone because it doesn't work like that. I would recommend you to contact your operator for further help on how to download the songs with the credits from your phone since we don't work directly with that.
