scr 26 Cover
jacopo45
scr 26 Cover
Who knows when the scr26 cover will be available? I'm trying to order it in a lot of European shops but no one seems to have it!!
Hampus
Champion
The availability may differ from market to market. I suggest that you contact your local support team for further information about launches for your market:I'm sorry to hear that.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
tjharia
How do we disconnect the smart window from showing since android lollipop notifications are much better?
Andy_Dandy
There is a configuration option under Sound and Notification called Notification Access. If you go there and deselect "Style Cover" then the notifications will not go to the cover window......(I think)
