Try to force it to turn off by pressing power button and volume up at the same time (you will feel 3 vibrations). Then, let it charge like that.
Hi @Sonyz2userz,
Have you been able to try Alexdon's suggestion? If you are still unable to power on your phone I suggest that you try to perform a software repair using PC Companion with the help of a PC.
