Screen off problem
Mark0l_
Screen off problem
Hi, I was searching through forums but couldnt find answer.
I upgraded to ICS and now it seems to me, that some features, apps dont work when screen locks. Let me give an exmaple, when I set alarm not in build-in app It wont ring unless I turn on the screen. A led notification also doesnt work, but I read that it is to save the battery (I would sacrifice this 1% of battery/day) 😕 I tried some app that should indicate sms and calls with LED, but it also didnt work. Is this problem of applications, ICS or  thi eco mode of battery (one which turns of data and wifi) ?
Thank you
4 REPLIES 4
eljunpacomios
What ICS are you running?
I haven't experienced these problems..
Mark0l_
I'm runnig 6.1.1.B.1.10 . Newer version is not available in my country.
I'm experiencing this problem also with Any.DO
eljunpacomios
The one that you installed might not have permissions to access
some of the phones features.
Try using the stock applications for your alarm, sms and calls and see what happens.
Also, try restarting your phone. Turn it off for 1-2 minutes and turn on. And check the stock alarm/sms/calls notifications again.
I am also running on ...B.1.10 and my Xperia Go is at most, if not all, good.
kris1441
take a look at performance assistant if you already update to ICS..maybe the apps is disabled automaticly by the performance assistant. you can ebabled it back by ticking the box on related apps.
