Good Day,
I own a Xperia Z3.
I installed a 32Gb micro SD.
Everytime I transfer data (music or photo) on the card, it become corrupted. There is no problem with everything that stay on the internal memory.
The problem is present if I transfer through the phone or through the PC app.
I first tought the card was the problem. I tried it on the PC, I tested it with an app on the PC: the card is fine with no error. I also tried 2 other cards, they all do the same.
Anyone can help?
PS: I send an email directly to Sony, and they never answered me.
If I understand you correctly, you have tried different SD-cards and the same behaviour appear on all of them? The files that you transfer, do they get corrupted directly or after a while?
Have you enabled 'encryption'?
It has been happening the same with me. The files get corrupted after a while, is there any solution? I've tried diferent sd cards and problem remains. Thank you
