Sd Card Problem
swapna_g
Sd Card Problem
Hi, im unable to view contents of my micro sd card im my xperia j.Initially i used 2gb san disk micro sd for 4months bt at that time i din't face any issue. just one month back i bought 16gb sony micro sd card. I tried my sd card in other mobiles itz working fine.:smileysad:
11 REPLIES 11
Samuel1
Hero
Seems strange. What happens when you try to use the card, what issues are you having?
What are your thoughts about this forum? Let us know by doing this short survey.
swapna_g
Here, are the screen shots when i open my walkman and album. when i place my sd card in other mobiles likes samsung im able to view all my contents.Kindly let me know why it is happening in my xperia j.album.png
swapna_g
In storage it is displaying like this
Samuel1
Hero
Sounds like there might be something wrong with the SD card reader here. You could try to repair the phone software via PC Companion at first:
http://www.sonymobile.com/update
If that doesn't help you should send in the phone to a service center for repair. Contact your local Xperia Support for more information:
http://www.sonymobile.com/global-en/support/contact-us/
swapna_g
I think the problem is with my phone.It is showing error "memory card out of space.Audio,video functions are not available now".
Samuel1
Hero
Yeah it sounds like you're right. I would then recommend that you follow the instructions I mentioned in my last post.
swapna_g
I tried updating my phone many times.But,every time it shows error "could not download" after 98%..:smileysad:.
Even yesterday i tried but the result was same.
Samuel1
Hero
Alright. In that case you should try sending in the phone to a service center for repair as there isn't much you can do by yourself.
swapna_g
ya il do that..!!
