SmartWatch SW2 USB Cover Won't Open
RayG
How do you safely open the SW2 USB cover without damaging the cover?
I have found reports that people are having trouble opening the cover as well as accidentally breaking off the cover from it's connection to the watch by a small plastic strip.
Uliwooly
http://userguide.sonymobile.com/referrer.php?region=global-en&product=smartwatch-2-sw2#!Charging---A...
Since its water resistant its a bit tight but just use your nail and you should be fine, don't use too much force
