Hi uliwooly, thanks for your help... the annoying thing is that these bugs happen only intermittently to my phone, it's not a constant thing. I might go weeks with no issues and then suddenly i get a few days with the phone being buggy.... I guess I'll just have to wait till it happens again and then try the safe mode thing... and if that doesn't work i'll try the xperia companion option that @edmonddantes1829 suggested.
I still find this pretty unacceptable though, because the same apps i used on my old phones are the ones i'm using on this new phone so there should really be no excuse for it to be so buggy
Keep in mind that because an app works fine with a phone, it doesn't mean that it'll be the same with other phones, if you find a bug with an app, you have to contact the app developers.
