After updating my sony xperia l to 4.2.2 it shows some misbehavior. Each time when I turn on the phone app menu will have a new alignment and some of the widgets in the home screen will also disappear.
plz help me with this
Hey swipe your finger in left side when yoo are in menu screen. its new UI like z1 try it you can see them the alignment..
Just reset the ph from settings>backup & reset> Factory reset data..
I guess this will solve the problem..
do backup contacts and messeges before reset.
