I have more than one SE mobile phone but am now having problems with one of the models. My W395 screen got crashed and therefore I cannot see any numbers or anything really.
Thought I would be able to retrive all the info with pc suite but as far as I can see pc suite does not work with this model.
Any suggestions?
Send it in for repair.
That was not a very helpfull answer.
I don't want to repair it. Not worth it. Just expected to be able to retrieve my info as I have always been able to do with SE.
I guess this won't be the case.
Well if you can't retrieve the information via the PC in Mass storage mode, you can try using software on the internet that claims to retrieve information from the phone, although this usually works only if the information is on the memory card.I have had this phone in the past and because there is no update for it and it's not compatible with PC suite, the only other reset/repair option is a master reset, providing you can still see the screen, which you can't.Of course,a master reset would wipe the phone data anyway, although SIM and memory card (which you can remove anyway) data should remain intact.If you have data on the memory card you want to retrieve, you can of course either use a USB card reader or another compatible phone.If you want to retrieve contacts from the phone memory which you haven't saved to the SIM, then you need to try phone memory recovery software.
