I have been using my Xperia M2 Aqua for more than a year now without it missing a beat. After the last software update however I have started experiencing problems such as the touch screen being very unresponsive, the phone being overall very slow and, the most frustrating, that it does not lock the screen when I am taking a call. Before the latest software update, the phone used to lock the screen as I was moving it to my ear. This is resulting in functions being performed while I am taking a call becaues the screen registers my jaw movement as actions on the phone. It only started doing this after the latest software update. I have tried restoring the factory settings to going back to the previous software version but that did not work. Please can anyone assist with this??
Hi @Bigboss372,
Sorry to hear that.
Do you mean that your display is not going black during phone calls? There is a sensor on your phone that is supposed to turn the display off during calls to make sure that you do not press the display and end the call accidentally.
You can test if this is related to the sensor or not by going to Settings > Diagnostics > Test > Ear proximity. Follow the instructions displayed. Did your phone pass the test?
Hi Didrik,
I'm experiencing the same problem. I did perform the proximity sensor test - it switches to "ON" when I cover the sensor with my finger.
Best regards,
Mette.
I'm affraid it's not a consistent problem - I cannot replicate it now, neither in safe mode nor in normal mode.
I have experienced the problem several times, but I'm not sure under which circumstances it occurs.
\Mette.
Hi @Amear,
It sounds like the update was not installed correctly. In this case I'd advise you to perform a software repair using Xperia Companion. To do this your phone has to be turned off, you can force the phone to shut down by pressing and holding the power button and volume up button at the same time untill the phone vibrates.
I'm not sure I fully understand you. What was the exact error message you received in Xperia Companion?
Do you mean that you have unlocked the bootloader in your device?
