Encrypting your phone through the default method is an irreversible process. You cannot decrypt your phone later. You cannot stop the process in between either. Try using Sony Update Service on PC to repair your phone, and if it doesn't work, then probably you should seek professional help at a Sony service centre.
encryption gone seriously wrong.
no error messages during encryption.
phone restarted but when i enter the pin code nothing happens. except the phone reboots back to the unlock message..
i know it is the correct code i entered since any other will show 'try again'
tried connecting to pc but phone won't connect.
solution please?
thats exacrly what happened to me, did you find a solution? thanks
I've exactly the same problem with SD card 32GB SDHC class 10 inserted and encryption activated. Phone keeps rebooting after encryption password submited. Without SD card inserted encryption worked on my Xperia SP.
Peter
