It is waterproof,but up to a specific depth only. Water resistant means it can take a specific amount of pressure (this is also up to a depth). This is as far as I know.
However, waterproof also means no water comes in the device,while water resistant means water can enter the device but it won't affect the inside (pressure limited).
The sony xperia Z3 has a IP68 certification which means its dust tight and waterproof*
The IP6X means no dust can get into the phone
The IPX8 means the phone is waterproof and can be submerged for 30 minutes in a fresh water and upto 1,5m of depth.
If you claim that all covers were closed then you should immediately contact sony and request for a vacuum test. They HAVE TO replace it if they find a device fault.
Is Xperia X3 water resistant? I'me reading lots of complains in Turkey and other websites thet shows water damages this phone very easly.
Also lots of complaints about technical support in case of water problem.
I expect some info about this issue from official technical responsibles of Sony and/or other users? I will decide to buy it or not.
I have moved your topic here as it is similar. Read this and maybe contact sony and see what answer do you get:
http://www.sonymobile.com/global-en/support/contact-us/
Your statement its not accurate, the phone its waterproof, you can request a vacuum test, that will prove who is at fault.
The vacuum test can only be performed by your Local support, if you are referring to the service menu test, that won't work.
