can we use stylus with rubber tip found in the market on xperia t2 ultra dual?
Our Stylus E22 will not work, I've just tested. But there might be a third party manufacturer that have created a Stylus that will work. I suggest that you check with a local store if you can try a Stylus before buying it or check with the manufacturer if they have tested it.
So, here's my question ❓.... Being a Xperia loyal User.
Can't I expect something creative writing, drawing, sketching or Doodling. If I'm buying that range of smartphone. One special features should be there. So here I'm with Xperia T2 Ultra. I like to design, doodle but I can't do any better.
So please suggest me some accessories.
A bit help from me.
So T2 ultra use
CAPACITIVE touchscreens work by sensing the electrical properties of the human body, while RESISTIVE ones operate by sensing direct pressure applied by the user.
I used to try other manufacturer to find out that their screen is a resistive one.
There's a capacitive screen stylus on market, but some.of.it is expensive.
But it's better because of the sharp shape make it feel like using a pen.
I have bought a cheaper one and it feels like using a giant marker.
Everything I draw is big
Hope it helped you., sorry for the big font. Replying at my phone currently and can't find out how to change it.
Oh and by the way., maybe sony could make a capacitive stylus. It might sell well for almost all.of their phone with capacitive screen
