Stylus support on Xperia z2
neznim
For the past few days, I have been researching about the stylus problem on Xperia Z2. I have tried 3 different styli and my Xperia Z2 does not react at all. Will this problem be fixed or I just need to give up using a stylus on my Xperia?
8 REPLIES 8
Thommo
Genius
I'm sure I read that it depends on the stylus and what the tip is made of - If it's a conductive material like metal then it will work and I have just tested this and it works for me
dandy63
Leader
Capacitive Tip stylus works.......i use it on mine :smileysmileywink:
neznim
Thanks guys. Would you guys be able to tell me what brand of stylus works? Because it would be great if I can just get the right one at the first time. Thanks in advance Winking_Face
dandy63
Leader
The one i use is not any special/specific make......think it cost me around £5 but it works fine, just get the best capacitive one you can afford.....but not silly prices Smiling_Face_with_open_mouth_&_closed_Eyes
neznim
Thanks Dandy for the swift response! Definitely getting one tomorrow!
profile.country.GR.title
reptile64
At work I use a simple metalic pen and it's working fine (!) you can try with the tip of a lighter and see for yourself that every metal object is working fine on this screen!!
dandy63
Leader
Metal on the screen.........not a good conbination....or a lighter Face_with_rolling_Eyes
Rperry
I want to know if wacom fineline stylus works over xperia z2 screen. Anyone used this kind of stylus?
