Support, RMA help
Support, RMA help
Can you guys help find out where and what i have to do to fix my x10 by sony ericsson it looks like my usb port for charging does not work i tried few chargers none of the worked i went to the service and the guys there told me that usb port is broken. But when i put charged battery phone works ok. So i want you guys to help me find out some application or something to fild out and send my phone to SE to fix it. I cant find any thing about RMA process, plz help
If you bought your phone through your cell provider you can call them and they will take care of replacing your phone (if its still covered under warranty).
