The SIM card
pause
The SIM card
Hello,
 I have bought a new Experia M5. It says"no SIM-card-only emergensy-calls". The SIM-card is activated (I have checked that). Now to my question: Shall I put the SIM-card with the GOLDEN side DOWN or UP? I dont know if I have put it right in the cover. Anyone know what I shall do to make it work?
5 REPLIES 5
Uliwooly
pause
Thanks.... I´ve already seen this, and I cant figure out if the GOLDEN side shall be DOWN or UP... the text does not mention this issue
Uliwooly
@pause
look at the shape of the SIM on the diagram. As you can see, a SIM card it's not a perfect rectangle, use that to guide you.
pause
ok I´ll have a look ... thx
Uliwooly
@pause
Did you figured it out?
