there is insufficient space on the device
Fajar
my play store ui was changed to new look, but my play store cant download any app such as app with size 5 mb, my storage still 90 mb... why?
i screenshoot my problem
http://i1369.photobucket.com/albums/ag235/darkzila16/Screenshot_2014-08-14-22-06-14_zpscbb19384.png
24 REPLIES 24
rrm
MERGE the internal & device memory which is a unnecessary part done by SONY and not seen in other manufacturer. It will help solve the memory issue to a large extent
keshav_k29
How can we do MERGE? Do I need to root my phone for this? Or is there any other way of solving this problem?
ankit_ms
**bleep** solution not found here
MANAF
dear ...download
Mobogenie
 from your pc and copy the app to sd card..after fo to sd card from mobile install the apk file of mobogenie..download apps and enjoy..(mobogenie is like similiar as playstore and they have resume option. )
download link.. copy and paste to browser..
http://www.apk4fun.com/apk/6027/
PratheeshPK
My xperia c, When download app from playstore There is Insufficient space on the device.
Ya_Kha
Can't the internal and external memory be swapped and issue can be sorted out.
Romeo143
Guys download and update with mobigenie app....it's temporarily solution
Romeo143
Settings>storage>device memory
Cached data >Clear Cached data >OK
Now download
bksondagar
Hey dear,
it seems your internal storage has lot of app cache stored in it.Try to use cleanmaster like android app that would be able to clean unwated junk files stored on internal memory of your device. It would help you.
App2SD is another resource that help you to move your internal storage app to your SD card,this will also do some free space on your device.
Read this, it might help you : How to Fix Insufficient Storage Available on Android
Clean Master App : Play store link @ https://play.google.com/store/apps/details?id=com.cleanmaster.mguard&hl=en
jojodr
i have the same problem insufficient memory though i have a lot of free space
