transferring sms messages
hi there x10 users.. would like to ask if there is any option with the x10 that you can transfer your text messages from your old phone to the x10? i have sms messages in 2 of my old phones (blackberry storm 9530 & sonyericsson k800i) that i would like to transfer.. is there anyway i could do this?
4 REPLIES 4
i have exactly the same issue.
i need to transfer text messages from my K800i to my xperia x10 mini pro.
i couldnt find a way of doing it in windows explorer, maybe a software is needed?
any help would be awesome!
I was using K790i and Now I am using xperia X10 mini pro I am also having the same issue.
Someone plz help.
If the messages are saved in the phones memories (as opposed to the sim) and there aren't a lot to be transferred,can't you just forward the messages to your new phone? This should be possible as long as you have more than one sim card.
David
Uliwooly
I can't find a way to transfer the txts from other phones to an Android device, one thing you could do with your X10 is use this
http://gadgets.apnafundaz.com/2010/10/myphone-explorer-supports-android-download-now-pc-suite-for-an...
that will give you access to everything in your phone through your computer, also, the more txts you have stored in your phone the slower the messaging app will get.
