Unable to download from Playstore
rashekar
I'm unable to download apps from Google playstore. It accepts "Install" and "Accept" and thereafter goes into downloading mode but never downloads even after several minutes. The blue lines keep scrolling from left to right.
Can anyone tell me why this happens?
Thanks,
Shekar
4 REPLIES 4
dandy63
Leader
Hi, could be either a network issue at that moment or possibly the Play Store exceptionallly busy or the actual App you are trying to download, i have encountered this a couple of times but it usually resolves after another try, you could also try clearing the Cache in the Play Store App or even try deleting/reinstalling the App.....
Good luck :smileysmileywink:
Hampus
Champion
Just like
Uliwooly
You can also test Safe Mode. Do you have any taskillers or antivirus apps?
rashekar
I did a software update and now I'm able to download from playstore.
Thanks all for your suggestions!
Cheers,
Shekar
