recently after i updated my xperia z1
Android version: Android 5.0 (Lollipop)
Latest available software: 14.5.A.0.270
Release started: 2015-05-20
i havent been able to download HD games e.g MODERN COMBAT 5, MORTAL COMBAT x, i tried to look for a solution online but none of them works.
i tried this option
Menu > Settings > Apps > Google Play Store > Clear Cache. Clear the data
it doesnt work
can you please help me?
the only reason why i bought the z1 cause of the experience of playing hardcore games and now i coudnt.
... starting to think sony is not that great anymore
This problem is not specific to Sony, it was reported on all manufacturers even on Nexus phones running 5.0. These apps are using Adobe Air and were not fully optimized to work with Lollipop, and there is no sure shot fix for the issue, but you can try the following:
- Settings -> Apps -> All -> Google Play -> Clear data and restart your phone.
- Create another user, check if they are on your app list there, uninstall them, and go back to your original user and try installing again.
- Phone repair with PC Companion.
