usb problem
kartikmandavia
usb problem
when I going to copy any l gb video on my Microsd card via pc then after copy 50~60% mobile automatically disconnected with pc and copy stop what will be reason
Alexander1
Champion
Sounds strange. How big are the videos you are trying to transfer?
Do you experience any difference if you change the USB connection mode under settings > Xperia > Connectivity > USB connection mode? Change between MTP and MSC.
