while video calling or while using skype my phone laggs a lot and i have to reboot it every time i videocall ther is no speed issue my 3g and wifi speed is very fast.................sometimes it shows the camera error .....:smileyplain:
that's an app issue, does this happen with other apps or just skype?
same with fring and tango
it shows like unfortunately fring is not responding same with rest of vc apps
Are you using ICS or GB ?
gb
Have you try to kill apps before you open skype?
stay away from task managers, task killers, antivirus, ram apps, battery apps, instead try this
if you have any of the apps above uninstall them and try again .
no i kill apps after using skype
ok i will try
